I'm pretty sure my bus weighs more than the 18,000 lbs tax base it's registered for, but it's still a whole lot more honest than the 5000 lbs tax base the guy at the DMV suggested I register it as to save a buck or two. I'm not sure about the GCWR as my bus doesn't have it stamped on the plate, nor does the book give any insight. I think a good starting point would be finding out what the tranismission's max GVWR is. I'm pretty sure the AT545 is the weak link in my bus in terms of towing.
Regardless, I will not exceed 10,000 lbs with a trailer as that requires a CDL. Also, if the combination exceed 26,000 in Minnesota you need the CDL. Basically that limits me to an 8000 lbs trailer with my current plates. Realistically the heaviest thing I can ever forsee myself towing is my truck (on street tires) with some spare parts, tools, and the swampers in the bed. GVWR on the truck is 5350 in stock form. I'm sure I've added plenty of weight with my various modifications and I'm pretty sure it COULD haul more with the suspension I've designed, but I really don't think it weighs more than 5000 lbs right now.
IIRC, the "passengers" on a bus are allowed 13 inches of room for their cottom side and are allowed to weigh right around 125-135 lbs. You could use that as an estimate of weight. Funny....our buses are built on similar chassis than a lot of straight trucks, dumps, etc, but seem to haul way more day in and day out than any single axle gravel hauler could think about.
