SamDee
This is a shot with the platform removed. In the middle to the right of the bucket is a black hose with a white golf tee in the end. This is the air line feeding the air ride seat. To the right of that in the floor is one of the holes through which the platform was bolted. The hole to the bottom of the picture by the same amount from the air line is the hole the seat retention loop was bolted through.
This is the same area directly under the driver seat taken from the stair well. This is after having used a wire brush on the angle grinder. Notice the white dot in the lower left, that is the golf tee as viewed from the top.
And finally, the same area as above witha liberal application of Ospho.
Ah brilliant! Thank you very much for that. All tho I believe mine is built differently! When I go under the bus the drivers platform is actually higher than the original bus floor. So its not like a platform placed on the original floor!
But I think your right, I will take out the driver seat and remove the flooring from under it. If I'm sealing and treating the rest of the bus it would be foolish to just leave that small 1m sq! Ill pull it out today and upload some pictures!
thanks!
