girasoledonna
- Joined
- Jun 15, 2016
- Posts
- 26
ooo i will look into them if they make them shorter than 35!
Coach ran our school's activity bus at 80, EVERYWHERE he went.Dude, I was going 63 for 800 miles watching EVERY vehicle leave me like I was standing still.
For interstate miles a real coach is FAR superior.
Interestingly, some school buses CAN go 80 mph stock. But they don't have the ride and handling of a coach.
Found this on YT this morning- sucker must have a RAD drivetrain
Depending on where you're reading or whom you're speaking with, "coach" is often used interchangeably with "RV" or "motor home". It's also used to denote road accessories as opposed to parked (house) accessories; IE coach air vs. house air. I was at an RV dealer a few moths ago and the salesman called a Class B a coach.
When you're hanging out with bus or RV conversion folks, a "coach" means motor coach. Skoolie is obvious. Bus is generic.
Cadillackid thanks for that info about the low flooring. I have seen a lot of low-floor buses and did not put 2 and 2 together about tanks. I wonder where they would put the tanks with such a low floor? Although a low floor would likely mean that there would be more head room?the transit busses ive ridden and driven dont drive well (to me) on the highway... plus a lot of the gilligs we have currently in the fleet here in columbus ohio have a wierd floor line.. with the last 3rd of the bus raised up a foot or two...
the busses do run 65+ on the highway as the transit routes (express routes) take them on the freeways..
most of them do have air-ride as they "kneel" them for wheelchair and handicapped people to enter and exit... the ones here in town also have air brakes air seat and tilt / telescopic.. they have road A/C, tinted windows...
people can and do convert transit busses.. there was just a FLXIBLE rally here in ohio.. I didnt make it up but pictures i saw were of some later model (90s) transit busses that had been driven a decent distance...
I know our city runs mainly all gillig transits.. and for some routes (the city circulator that goes in the historic districts) are shorter than the normal busses.. but I dont know by how much.....
our transits also seem to have low floors even before kneeling so im not imagining there much space underneath for plumbing , tanks, generators, etc...
BusFiend... would you advise me against buying a VERY old bus... like something built after 1980? That certainly IS old ( i was born in 82 after all hahahah) just to keep it under 35? Or would I better off, based on being faced with a very old bus or a school bus to stay under 35, to go with a school bus?
Or maybe I should throw out the 35 rule? I just wanted to be able to get into national parks? My boyfriend is disabled from his traumatic brain injury and we can get into all of them for free.
Very good post!Well maintained, a coach will go almost forever. A skoolie, well maintained, is a 300-500k mile bus. The example that EastCoastCB posted, is probably one of the best MC5s on the market. It's a great opportunity if still available. You will end up spending close to that $21k (or more) converting a skoolie. For the essentials, it is turn-key. Plan on a Skoolie taking a year or longer to convert, especially for full-timing (though you will probably never be finished).
Most of the MCI5s or cheaper other coaches will have manual transmissions, requiring double-clutching or rev matching. Most skoolies will be automatics. Most professional coach conversions will have a 10" roof raise. Coach conversions will require plugging in to "shore" utilities for anything but a short overnight stop or running your gernerator constantly. The same $5-10k can be spent on any bus for solar/boondocking capabilities.
The MC5 will go most places. Modern Class A motor homes have been 40-45 feet for many years now. Check online to see what the requirements are for the national parks (and other areas) you want to visit. Ask around on other generic RV and full-timer forums to see what they have to say. Probably a good rule of thumb is a coach will want to stay mostly on pavement and maintained/graveled surfaces. A skoolie will be a bit more flexible but certainly not an "off-road" machine.
TL/DR: A coach will probably be a turn-key RV for you. A skoolie will be a DIY or contracted project. The former is a heavy duty platform, while the latter is medium duty. Maintenance and repairs will be slightly more expensive for a coach. A coach will be a much more pleasant over the road vehicle (ride, A/C, etc). A skoolie will go some places a coach will not.
Have you driven both a school bus and a coach? You might want to do that, if you haven't already.
Good luck, Anj! Keep singing!
can you tell me what double clutching and rev matching is? I don't drive stick but would be happy to learn for the right bus.Well maintained, a coach will go almost forever. A skoolie, well maintained, is a 300-500k mile bus. The example that EastCoastCB posted, is probably one of the best MC5s on the market. It's a great opportunity if still available. You will end up spending close to that $21k (or more) converting a skoolie. For the essentials, it is turn-key. Plan on a Skoolie taking a year or longer to convert, especially for full-timing (though you will probably never be finished).
TL/DR: A coach will probably be a turn-key RV for you. A skoolie will be a DIY or contracted project. The former is a heavy duty platform, while the latter is medium duty. Maintenance and repairs will be slightly more expensive for a coach. A coach will be a much more pleasant over the road vehicle (ride, A/C, etc). A skoolie will go some places a coach will not. A coach will also be mostly made out of corrosion-resistant materials (aluminum, stainless steel, fiberglass, etc.). A skoolie is good old galvanized steel that will rust.
So i can spend 5-10 K and get solar panels on a coach as well as a school bus? (as I get it).
School buses need to plug in too don't they? Or do they need to plug in less often because they require less power to run?
When you say heavy duty platform vs medium what do you mean?
I have driven neither hahah. The only thing I drove was a class C and a class B, when I was shopping three years ago for my Class B. I am a badass lady though and am sure I can handle either with practice. But I'm sure a school bus is easier to handle?
I do LOVE that MC5 you sent me via youtube! I hope they get back to me... although I don't have all 20K to throw at it - they said they lowered the price to 18K and somebody messaged them a week ago asking to buy it. So i don't know if its still there. But, even if it isn't, its given me a lot to think about with conversions, and I'm sure another would pop up. The coach shot out white smoke when he revved it up - said that was normal with the engine. Speaking of engines, anything you tell me to be on the look out for?
