It is pretty easy. Took me an hour of measuring and cutting. Take a 1" hole saw at each corner.. Cut the center out ..deburr.. And use sikaflex or similar to glue a piece of lexan onto it.. Light comes in and operable as hatch or vent.
Not sure what you mean by "making a flange"? The hatch hole is 24". I bought tinted Lexan, 26" to cover the hole using screws and butyl tape. I will seal it further with the roof coating or a sealer. I then cut a 14" hole centered in the Lexan to mount the fan/vent. This way I still have a surround of ambient light coming through.
Assuming that you have pulled out the inner sheet metal roof skins, use that sheet metal and cut a square that is a couple inches bigger in both dimensions than the hole left when you took out the hatch.
Line the edges of the patch with butyl tape that will be sandwiched between the outside of the bus roof and your patch.
Then use short self drillers on 2” centers to attach the patch. Clean off excess butyl tape that squeezed out.
Check for leaks.
Then use the fantastic fan template to mark and cut the fan hole in your patch.
Paint your patch to match the roof and install fan.
Check for leaks.
Wire in your fan to your 12v load center.
Enjoy your fan!
I was wanting to install either a max air or fantastic fan. As we all know they don’t fit exactly. My intent was to make a flange of sheet metal to cover over the existing to escape hatch holes. I’d like the fans to be where the escape hatches currently because my escape hatches leak anyway, win win. Can anybody tell me if the flange idea is good or bad, I’d really rather not cut new holes?
Hmmm
I take a piece of steel and rivet/screw it down over the hole. Then cut a hole for the roof vent. Its pretty easy.
Sadly my sub ceiling was perforated.. I'll have to find two steel plates elsewhere.
If you have any seats left over, you can cut the back panel of steel out of them and use them for a patch. They are 27" tall. just right.![]()
Can the seat backs be used to patch holes in the floor, or is the steel too thin for that? I have 22 seats and a strong urge to do further damage to them.
Thanks, man!
I've used them a bunch for bus metal work.
Does anybody have any recommendations for what brand of skylights to use to replace the current emergency hatches? Also what brand exhaust fans have you guys seen work best? I'm at the point where I'm ready to paint my roof and figured I'd do all the roof stuff at once. ANY advice wold be appreciated.
