paxye
I live in an extreme hot and cold climate so I really want to insulate as much as I can. Now, we are starting this build as two people who do not have much experience. I do learn quickly though.
So first... we have to stock AC units in the bus at the moment. 1 works, 1 doesn't but it might be just a fuse I was told... we don't know though.
Second, there are the stock heaters.
So what would you do? I am thinking though they take up space etc to keep the heaters. I am not sure about the AC units... Could they all be run off shore power instead of just the bus? if so how does that work? or not? I told you I was a beginner!! If not... are they more for only when driving? Are there any other reasons to keep them?
I have read many conversions here that just built on top of the floors and didn't rip anything out and then many more that of course ripped out the ceiling and the walls to redo insulation and ideally that is what we want to do but the rivets scare me... so many!! I guess my question here is about how you do it. I have seen drill the middle then use a dry chisel and hammer. What drill bit works best? What tools are needed? There also seems to be two types of rivets.
For the floors... do you start by un screwing the center isle? Are there any tricks? the floor looks really thick and I a bit miffed by what to do around the engine (we have a front engine inside)
Here is what we are starting with...
