Hey yall. Mostly have figured out how I wanted my solar panels mounted but wanted to run it by a few more eyes before I bit the bullet.
Running Unistrut on My 1984 MCI MC-9
22 Ft of Unistrut running in parallel. fastened with bolt down 1/2" fasteners (see picture strut 2)
Plan of attachment: I am copying this video almost exactly,
due to the similarity in bus and need for unistrut.
To attach the unistrut to the bus, I will use brackets. Brackets held in place by 3/8 - 1/2" lag bolts screwed into the metal support square tubing. Lag bolts will have a flat and lock washer combo underneath but obviously no nut on the through side, since there wont be one. Unistrut will then be affixed to the brackets via bolts and 1/2" unistrut receiving inserts (see picture)
Solar panels will then be screwed down with square washers and a rubber washer underneath held in place by 1/2" bolts. (see picture)
The reason I chose this attachment method is the ceiling is already installed earlier than I had anticipated. (brother in law surprised me with some tongue and groove installation, but didnt know I had a need to mount the solar first!
Questions:
Thoughts on use of lag bolts for this situation for bracket install? He mentions they have held well for several years of use.
Would you use 1/2" or downsize to 5/16" or 3/8'' ?
Anything that you would do differently or change knowing that the ceiling cannot be removed? The middle support beam IS still accessible for the meantime.
Questions:
