Hey everyone, long post ahead. If you feel like you can contribute on solar mounts, I, and anyone reading this later, would be very grateful!
We have 6 320w Renogy panels. They aren’t particular light, or small. About 40lbs each, and 40”x66”.
Fitting them on our roof will be a tight squeeze, but should work in theory. I am however terrified of these things blowing off and hitting someone on the highway, so any wisdom here would be wonderful.
Things we’re working around:
Stationary sky light at front, max fan over kitchen (middle), sky light / emergency hatch in the back along with a smaller 7x8 deck.
We also did a roof raise, so we have a transitional panel raising about 16” over 2’ at the ribs right behind the front door. I could theoretically place a panel on this transition at a somewhat weird angle (see just another skoolie), or in front of the transition on the very front of the bus.
I have some z brackets, and will be using them where I can, but given the curve of the bus, I will have to improvise on the sides where I have as much as a 5” drop.
I have seen some use heavy duty galvanized gate hinges for drops like this - is that actually safe? I’m sure they won’t hurt, but I’m not sure I would count on them without some verification that it’s a legit bracket alternative.
If I did install some struts bolted down to the ribs, how could I secure them without having the end of the bolt sticking through the ceiling? (Ceiling framing is placed on the sides of ribs to save space, so the bottom of the metal rib will essentially touch my tongue and groove ceiling)
Would a unistrut system significantly add to the structural integrity of the rig?
Would a slight forward angle on each panel help aerodynamics? Without a wind tunnel, it’s hard to know exactly how the wind will be hitting these things. I want to avoid them acting like a sail as much as I can.
Has anyone here build a wind shield? If so, how? Is it necessary?
Would a panel at the very front of the bus catch too much wind coming over the top?
Would an awkwardly mounted panel at the transition be helpful as a wind break, or a hazard? I’d also be concerned that it would not be as efficient if it’s at a different angle than it’s series partner.
Thanks for any and all input!
