Hi,
There is a general rule that the ideal solar/battery system is based on 1 amp of battery to 1 watt of solar panels. And the size of the system is based on your daily power needs plus how many days you want to go without sun.
To start out with a giant battery with no way to charge it is putting the cart before the horse. In this case most people end up having to run a generator most of the time and pissing everyone off around them. If you have any money at all, buy solar panels. You can find batteries anywhere. the problem is charging them. Of course none of this may matter to you because of your lifestyle. It all depends on how you live with your system and whether or not you have a power pole to plug into.
There's a lot more than just a fuse box involved. With 1800 amps of batteries you could melt your bus. The best way to figure out how to hook all the stuff up and what other stuff you might need is to refer to the manuals that came with the inverters and charge controllers. They will tell you where the fuses and shunts and circuit breakers go. It freaked me out too but they covered everything. Also with 1800 amps of batteries, all the wires, fuses, breakers and anything else involved has got to be BIG, and I mean REAL BIG meaning REAL EXPENSIVE. I found out by going thru the process and trying to fake it and buy stuff at the junk stores and wrecking yards. You go from a 20 amp fuse for $2 to a 500 amp low voltage fuse for $200.Big amps means big bucks.
I have lived with solar panels for more than 20 years and seen many people who live with them also. Almost ALL of us had enough batteries. ALL of us did not have enough solar panels. Two days with no sun and we were in the dark. We were always trying to get the batteries back up to 100% after days of cloudiness. I say again, The ability to charge is the weak link. Solar panels first, batteries second. Just my humble opinion.
The main reason we have so much power now is because we have a 10.5 cf 110 volt refridgerator. We bake our own bread. Soon we will be making our own beer and growing our own veggies Aeroponically (growing in the air) Electricity comes in handy when you have to make everything yourself and are just trying to survive with little or no money.
In my bus I have 1580 watts of solar panels
1580 amps in 8 Trojan L-16HC Batteries.
2 MX60 70 amp MPPT Charge controllers
3000 watt sine wave inverter
Backup is a 2000 watt sine wave inverter generator with 100 amp 110 volt charger and a 400 watt air-x wind turbine.
Good Luck
Jerry
