RagingGumby
So I purchased a kit. Its a 6500W 48V SOLAR CHARGE INVERTER PARALLEL + WIFI MONITOR UL1741 with a 390VDC max and 8 450W mono panels that have 41.72v VOC. If I understand this correctly that means that I can wire them all in series correct? If I can should I? Or should I wire them in 2 parallel series? What are the pros and cons of either?
I am trying to plan out the wiring of the panels to the MPPT/Inverter and what gauge I should be using. All the panels will be on iron ridge xr1000 racks on my 33ft bus and will enter through a flange directly over the utility closet which will have the 2 rack mounted Lithium ion battery banks that came with the system.
If you have any inputs or thoughts I would love to hear it and also let me know if any other info would be needed. Thanks!
