Simplicity-SKO
I have about three threads on various aspects of my journey to resolving how to get my Allison MT 643 electric modulator to work.
This is the solution I came up with.
After much troubleshooting I determined that the ECM was not sending the signal to the modulator relay. Why, I don't know. I decided it was such a common issue that a workaround was the best solution.
Workarounds:
Electric switch at accelerator pedal. This problem was so common, W.W. Williams actually made a workaround using what appears to be a wobble type limiting switch. You can place the switch under the accelerator pedal so that when the pedal goes down X amount, the switch sends the 12v to the modulator.
Pressure switch. It was suggested I instead use a pressure switch off my MAP port. This was appealing to me because I could not get an actual W.W. Willaims switch, and I was not too excited about fabricating an adjustable mounting system and finding an appropriate switch. In addition, because I have a rear engine, running the wiring and such wasn't as simple or clean as I would like. Upon investigating this, I ended up with the following:
1 - Tee. My T444E MAP sensor uses a M10x1 male thread, but the pressure switches have a NPT 1/8" male thread. I was able to find a Male M10x1/Female M10x1/NPT 1/8" tee. They ranged from $8 - $20.
2 - 8-13psi SPST Normally Open floating point pressure switch. Mine was factory set at 10psi and seems to work well there. The pressure range was based on determining where my MAP / Boost pressure ranges were running for my bus. You'll need to determine this using a boost pressure gauge and going out and driving your bus in different situations (city, freeway, climbing grades, etc.).
How I installed/connected the pressure switch:
1) I removed my MAP sensor, installed the Tee, replaced the MAP sensor and installed the Pressure Switch. Do NOT use any thread tape as it may interfere with grounding of the pressure switch.
2) I ran a wire from one of the terminals of the pressure switch to the positive wire of the modulator connector. I cut the modulator connector positive wire about 6" from the connector and connected the wire from the switch to the connector wire.
3) I ran a wire from the other pressure switch terminal to the positive from the existing positive wire out of the engine compartment flat blade fuse panel.
Your situation may be different from mine, but no matter where you get your 12v+ source, make sure you have an inline fuse.
My modulator measured ~2.5amps when 12v was applied.
My pressure switch is rated at 8amps @ 12v.
My OEM flat fuse was a 15a, so I kept it there, but may lower it to a 10a...not sure yet.
How do I know it all works?
1) I will be adding a light from the positive modulator connector wire to the drivers area. This will tell me when the modulator is receiving 12v. It will also give me a heads up if the modulator, pressure switch, fuse, etc. is having an issue.
2) I know what my bus shifted like before applying this solution, what it was supposed to shift like (thanks to a few key posters on here) and what it shifts like now.
It now shifts like a warm knife cutting through room temp butter...smoooth!
It shifts between 2600 rpm (low gears) to 2400 rpm (high gears) and sustains the high rpms the entire time. So sweeeet!
I'm not sure about this, but I think now that it's shifting properly, the engine ECM isn't trying to compensate and the entire bus is running so sweet.
Note:
Some situations may arise where your boost range when shifting into higher gears may fall below the pressure switches psi setting. A solution for this is what the call a cut-on / cut-off pressure switch. You need one that allows you to set the cut-on at a higher psi and the cut-off at a lower psi to work with your boost psi. I know these type of switches are available in the refrigeration industry because my friend works in that industry and he's the one that told me about them.
Since the AT545 transmission also uses this same modulator, this solution may work for these trannys too.
Thank You!!!
This has been a few months in getting to this point. I truly believe I would not have resolved this issue in such an elegant and functional way without great advice and generosity from this site. So very appreciated.
Hope this helps!
Workarounds:
Note:
Thank You!!!
Hope this helps!
