jfmusic@me.com
HI all, hope you are safe and warm. Installed 4 inches of Pink foam board under the floor. Have yet to complete the procrastinated floor heating. At 7 degrees outside temp. I have a 40 degree difference. And the steps and drivers area are between 14 degrees and 35. Steps are insulated under and over front wall is insulated with 2" and fiberglass which ever would fit. Most glass has reflectix and 1" foam
I also have found a half or quarter wall separating the Drivers area and the rest does make a big difference. I have a mini split mounted on the front wall, so a full curtain is not happening.
Be safe.
Be safe.
