LilBusDude
Hello all,
My 2002 E450 7.3 powerstroke will crank but will not start after a very cold night. There are no apparent leaks, and no DTC showing up. The Glow plug system seems like working. Something is draining my batteries very fast when i crank the engine, even when the batteries are connected to another running engine.
I have had a coolant leak from a freeze plug blow off that was fixed. And a UVCH pigtail shorting issue that was also fixed. Engine started fine when still warm the evening before that very cold night.
No unusual sound or smell or tail pipe smoke. Just an unusual rapid batterie draining.
Thermostat, Radiator, Tranny & Engine Oil, Coolant, Air filter, brand new. Gplugs, ICP sensor, CamShaft sensor, and UVCH less then 5k miles.
Still have to check fuel line at rear of passenger side valve cover to be sure. (Out of the "shop" until Saturday)
What else ??
Even though it's warm now it won't start since that night .. i'm stuck out here.
Could anyone point towards any direction ??
What else ??
