ewo1
SR. MEMBER - 99 Amtran RE DT466E HT 250HP-Md3060
24 Valve, 8.3 Liter Engine
Fuel System Troubleshooting And Repair Electronic Engine Controls
ok...did not know that!CAPS not applicable to my engine - it has a high pressure common rail…
You can borrow mine...but you need the software. I only have servicemaxx..No nexiq available…
I found my disc with the Cummins Insite software. I'd be happy to burn you a copy if you want it.No nexiq available…
I looked at a couple of videos on how to use this, and not sure how it would work if I am trying to find a short between the J1939 wires, as neither of them is a grounded wire - correct?Looking for broken wires is a painstaking time consuming job made easier with the right tools. I don't know if your familiar with the ECT3000 but it is a great tool to have in your tool box.
$75 bucks
I found one on marketplace in Houston real cheap. You might want to consider this option...
ECT 3000 on FB
ECT3000 I POWER PROBE
The new Power Probe ECT3000 Electrical Circuit Tracer is an intelligent short and open finder that makes locating short and open circuits quicker and more accurate than ever before.www.powerprobe.com
I worked as an underground telco cable splicer for Bellsouth back in early 2000. I was trained to work on "pulp" cable. Each individual 24 gauge wire was wrapped in plain brown paper, no color codes, no colored vinyl coatings on the wires...I looked at a couple of videos on how to use this, and not sure how it would work if I am trying to find a short between the J1939 wires, as neither of them is a grounded wire - correct? The wires do not need to be grounded for testing The ECT3000 checks for both OPENS and SHORTS.
I went yesterday evening and again this morning to poke around. Yesterday, verified that the ABS errors associated wheel sensors did in fact clear, (This is good news )but still have the 11/2 error (indicating loss of comms with J1939 Retarder…which I guess is maybe an internal ECM thing??). Also tried to read codes and live data (w/ ignition on) via J1587 link, as well as live data from J1939 - nothing on either and the live data message came back “no supported stream”. So started wondering if maybe the ECM is bad or in need of a reflash… I was curiously wondering the same thing but, you doing all the prelim troubleshooting will not only verify this concern but also save you tons of troubleshooting money!
This morning, I disconnected the batteries and waited a few minutes, then checked the C&D pin resistance on the J1939, and…zero ohms…as in the wires are shorted somewhere. Yes the wires could be shorted together Since the only thing I did from the other day was pull the TCM, I did that, checked the pin 7/8 resistance … it was low (forgot to write it down, but double digit, not the 110-ish of the other day)…checked the C/D pins again after reinstalling the TCM and it was 45 ohms….changed batteries in the multimeter just in case, but similar results, with some readings starting at 0 then building …. But still not close to 60. If the resistance reading start low and slowly climbs, there is an issue! Resistors do not respond in this manner. There could be several reasons why this is happening... water/moisture in a connector, wires shorted either to ground or shorted across another unassociated circuit and you could be reading resistance from that other circuit/short as well as cross voltage on shorted wires.... best would be to disconnect the data cable from all three places it terminates, all ends disco and try again. also, remember I spoke earlier about doing loop back testing on the wires... This is how I tested my cable for the tranny pushpad when mine went dark.
So, do I maybe have a slight short in the J1939 wires somewhere, and if so, how does the ECT3000 find it if neither is a ground?…do I ground one of them at the diagnostic plug? Safe to do so? You do not necessarily have to "ground" the wire...you just want to send an audible tone down the wire and follow the cable till you find the spot in crisis.
Interesting, yours is dated 11/05/2008 and the one I found is dated 03/21/2010.Where did you find that version of the wiring diagram? I’m not seeing it on the vantage portal under my bus number (F27077. Below is the version I have - it is for air brakes and does not include C303 and the resistor.
