Maddie-SKO
- Joined
- Oct 7, 2023
- Posts
- 2
First, I know this is not the best way to do it. For a long list of reasons the best ways aren’t available or possible, this might be. The bus is already converted and it’s where we live full time.
Second, I know that by not doing insert-thing-here I’ll still have air and thermal leaks and whatever else. For a long list of reasons I can’t address those right now.
Third, I’m mostly interested with making an improvement over not doing anything, even if it isn’t ideal or perfect.
I am looking to gain risk awareness around how I’m thinking of doing ceiling insulation.
I have a 2006 international skoolie. Removing the light and speaker rails there are holes where the wires were run and I can see whatever the stock insulation was. Water got into the roof so I want to remove the current insulation through those holes and a few others. I likely won’t get all of it but I’m hoping to get a majority of it. The ceiling is riveted and perforated and per the first two points they can’t come down.
I’m wondering what risks I should be aware of (health/safety) if I remove the stock insulation this way and then use spray foam insulation through those existing holes. I know there will be air leaks from other parts of the bus, and that I likely won’t get an evenly distributed spray as if I took the panels down but like I said in point 3, im just looking for an improvement vs doing nothing.
