Hi, I’m in the process of converting my StarCraft shuttle bus into a small workshop. I want to keep the original metal interior, but am in the process of tearing down the walls and ceiling to upgrade the factory insulation.
While tearing down the walls, I thought it was going to be simple to slide out the upper wall panels, but it appears to be locked in by this metal flange? I tried to gently ply it away, tap it with a hammer and a plank of wood to distribute the force, and also heat the flanges, but have had no luck getting it removed. The panels were originally caulked to the frame and I’ve removed this already. Before damaging the panel, I was wondering if anyone knew how to remove this without major damage? I’ve attached photos of the walls/flanges.
Thank you!
Thank you!
