bluebird90
Actually from what I've seen the gears should mesh close to 80% or you get shearing of the teeth. I have seen this a lot on GM type starters. On our type starters it usually means bad bushings, wrong flywheel or wrong bendix. Either way the flywheel should be checked or this might happen again.
