Fahntastic Life
Question about the bus stock heater.
I have an international 40' FN. My bus has two under seat fans and an Espar heater System mounted under the bus in the rear. For now near the driver seat, i have cut the hose and created a loop.
trying to see if people keep one of the fans system and use that to heat the bus while traveling.
do other people do the same. any pro or cons.
trying to do heater research. if the hoses contain hot fluids and goes to fan to blow hot air, what is the function of this Espar Heater system under the bus that the rear hoses loop thru. This heater system has its own exhaust tube.
