Subfloor adhesive vs XPS insulation
Tinglemd
Mar 3, 2018
6
Athens, GA
I'm planning on gluing down my 1" XPS foam board straight to my prepped and painted metal bus floor, then gluing 23/32 Advantech tongue and grove subfloor straight to the foam. I got my hands on a combination of Liquid Nail Heavy Duty Interior/Exterior adhesive, DAP subfloor and deck adhesive(interior/exterior), and TiteBond Subfloor adhesive (interior/exterior). Anyone have a reason why this would be a bad combo? The DAP product has a note that says it's not for use with "rigid plastic". XPS doesn't qualify as a "rigid plastic" for some reason, does it? Any reason anyone else can think of for not using any of these products for this application? I'm only planning on doing this once....
Thanks!
That is WEIRD. I’m literally installing the same setup tomorrow. Advantec and XPS 1 inch. However as the adhesive I am using pl premium. If the adhesive doesn’t state not for use with foams, it should be fine. It is the solvent based adhesives that screw with foam composition. Like lexel etc.
Man, that is crazy. Thanks for chiming in. Where are you in the upstate? I have good friends in Greenville, SC.
I live in spartanburg but work pretty much in Greenville at bmw. Holler if you ever come down we will have to grab a brewski.
Thanks!
Just do a test piece to make sure it doesn't eat your foam. I wanted to use advantech T&G but couldn't get it. Would have been so much easier to install and seriously hardy.
