Scratchy
Hello All! Long time reader, first time poster. I’m looking for some clarification and advice on installing a subfloor. I’ve purchased a 1996 Thomas - 65 passenger bus. My game plan is based on reading the posts in this forum. I’m looking for some confirmation I’m going down the right path and any advice or suggestions if I’ve missed something….
1. Remove seats, old flooring to bare metal skin of bus.
2. Clean, sand and repair any existing rust spots
3. Silicone seat bolt holes along with any other gaps, cracks, holes in the floor.
4. Paint the metal floor with Rust-Oleum.
5. 1’’ Owens Corning Foam Insulation – taping the seems tight.
6. Lay a “Vapor Barrier” down – 6 mil polyethylene plastic sheeting
7. ¾’’ plywood subfloor and painted again with Rust-Oleum.
8. Once all my wall studs have been seated - Laminate Flooring.
Vapor Barrier
I’ve read a lot of contradicting posts in regards to the Vapor Barrier – one says between the metal and insulation, other says between the insulation and the plywood subfloor. Which is it or both? One states plastic on top of metal traps moisture and another says if the plastic isn’t against the metal, the insulation is exposed to moisture. Not sure which to believe…
Fasteners
Typically, how thick is the bus metal flooring? Reading other posts, I understand some have fastened their plywood subfloor with wood-to-metal screws. Any recommendations on the type of fasteners to use? How far are they screwing the fasteners into the metal floor? If the fasteners go through the floor, wouldn’t be just as practical to bolt the floor down? By screwing down the subfloor through the insulation and vapor block am I not exposing myself to potential moisture problems? Is there another ways to fasten the subfloor to the bus?
Plywood Subfloor Thickness
I’m planning on using ¾’’ plywood for the subfloor as I mentioned above. When it comes to roughing in stud walls or securing bunk beds to the floor is there any recommendations or best practices? I intend to fasten to the roof for additional support on the opposite end of the stud for additional support, but I am having a hard time grasping the ¾’’ plywood is strong enough to hold on its own through toe-nailing screws or am I being overly concerned?
What else am I missing or need to be aware of? Thanks in advance for your assistance. Also, thank you to all who have posted pictures and how-to tips, they’ve been very helpful.
Scratchy
Vapor Barrier
Fasteners
Scratchy
