cadillackid
I hit send to early.. grrr
soft use isnt what kills the clutch pack.. (you could just have a stuck valve body piston as you mentioned.. thats what started happening to my 545 when it was run for ??? with a bad modulator)..
anyway what kills the clutch is full-throttle use with the modulator not extended.. so the transmission is shifting in a mode made for soft-throttle. only the driver is at full throttle.. so the shift is not as firm.. slides into gear which heats up and glazes the clutches making them want to slip more == worn down-to-the-metal discs..
