nikitis
I'm starting this thread for those seeking EFRC Rating codes for the T444E 3box Models for 1994-1997. Others may reply with their engines codes if they have that information. If you don't have a list of engines, if you look at your own engines label there should be an EFRC code and a HP value. Feel free to post your individual EFRC and HP Values and Bus year and type to help us build a database of these for reference should someone ever need them.
T444E/160 HP @ 2600 RPM [49 States 1994 Model Year is EFRC 2141, California 2111]
Model: T444E/A160F(49 States)/ T444E/A160C(California)
EFRC 2141, & 2141(California)
Injector Part Number: OEM: 1816187C2/C3
Turbocharger Part Number (With Exhaust Back Pressure Device): 1824703C91
A/R Ratio: .84
Turbocharger Part Number (Without Exhaust Back Pressure Device): 1824704C91
A/R Ratio: .84
Injection Timing: Not-adjustable
High Idle Speed - RPM with manual transmission: 2600 + 50
High Idle Speed - RPM with automatic transmission: 2600 + 200
Low Idle Speed - RPM: 700 +or- 50
Injection Control Pressure (ICP)/Voltage
@ Low Idle No Load: 590 +or- 50 psi (4.00 +or- 0.3 MPa)(0.94 +or- 0.1 Volts)
Injection Control Pressure/Voltage
@ High Idle No Load: 1020 +or- 100 psi ( 7.10 +or- 0.7MPa) (1.40 +or- 0.2 Volts)
@ Rated Speed and Full Load: 2470 +or- 150 psi (17.0 +or- 1.0 MPa) (3.15 +or- 0.3Volts)
Intake and Exhaust Valve Clearance (Engine Off - Hot or Cold)
Intake: Not-Adjustable
Exhaust: Not-Adjustable
Air Cleaner Restriction* [Measured @ Air Cleaner Outlet]
(Check at High Idle [No Load]) - Max: 12.5 in H2O (3.13 kPa)
(Check at Full Load, Rated Speed) - Max: 25 in H2O (6.25 kPa)
Fuel Pressure [Minimum]*: 20 PSI (138 kPa)
Fuel Inlet Restriction Maximum*: 6 in Hg. Vacuum (20.261 kPa)
Crankcase Pressure [Maximum]*: 6.0 in H2O** (2.0 kPa) (Requires Stabalized Operating Temperature)
The following data to be taken at full load, full throttle rated engine speed on chassis dynamometer or on highway.
Intake Manifold Pressure*: 15.0 psi +or- 2.0 psi (103 kPa +or- 14 kPa) @ 2600
6.0 psi +or- 2.0 psi ( 42 kPa +or- 14 kPa) @ 1500
Exhaust Back Pressure (After Turbocharger [Maximum])* 0-27 in H2O (6.7 kPa)
Smoke Level Max* - Bosch Number: 1.3 @ 2600 RPM / 1.3 @ 1500 RPM
Measure water temperature differential across the radiator with engine on a chassis dynamometer, at full load and ambient temperature of 80F or above.
Water Temperature Differential Across Radiator: 6-12F (3.3-6.6C)
The following data to be taken after engine reaches stabilized operating temperature.
Lube Oil Temperature (Oil Gallery): 230F (110C) Max.
Lube Oil Pressure at Operating Temperature
Low Idle (Min.): 10-13 psi (137-344 kPa)
Rated Speed (Min./Max.): 40-70 psi (276-483 kPa)
*Engine must be at normal operating temperature
** Crankcase pressure [maximum] as measured with Orificed Restrictor Tool ZTSE4146
T444E/175 HP @ 2600 RPM [49 States 1994 Model Year is EFRC 2151, California 2121]
Model: T444E/A175F(49 States)/ T444E/A175C(California)
EFRC 2151, & 2121(California)
A/R Ratio: .84
A/R Ratio: .84
Intake Manifold Pressure*: 17.0 psi +or- 2.0 psi (117 kPa +or- 14 kPa) @ 2600
T444E/190 HP @ 2600 RPM [49 States 1994 Model Year is EFRC 2161, California 2131]
Model: T444E/A190F(49 States)/ T444E/A190C(California)
EFRC 2161, & 2131(California)
A/R Ratio: .84
A/R Ratio: .84
@ High Idle No Load: 1020 +or- 100 psi (7.10 +or- 0.7MPa) (1.40 +or- 0.2 Volts)
Intake Manifold Pressure*: 18.0 psi +or- 2.0 psi (124 kPa +or- 14 kPa) @ 2600
7.0 psi +or- 2.0 psi ( 48 kPa +or- 14 kPa) @ 1500
Low Idle (Min.): 10-30 psi (137-344 kPa)
T444E/175 HP @ 2300 RPM [49 States 1994 1/2 Model Year is EFRC 2151, California 2121]
Injector Part Number: OEM: 1816187C3
Turbocharger Part Number (With Exhaust Back Pressure Device): 1823554C91
A/R Ratio: 1.0
Turbocharger Part Number (Without Exhaust Back Pressure Device): 1823553C91
A/R Ratio: 1.0
High Idle Speed - RPM with manual transmission: 2500 + 50
High Idle Speed - RPM with automatic transmission: 2500 + 200
Intake Manifold Pressure*: 15.0 psi +or- 2.0 psi (103 kPa +or- 14 kPa) @ 2300
Smoke Level Max* - Bosch Number: 1.3 @ 2300 RPM / 1.3 @ 1500 RPM
T444E/190 HP @ 2300 RPM [49 States 1994 1/2 Model Year is EFRC 2161, California 2131]
A/R Ratio: 1.0
A/R Ratio: 1.0
Intake Manifold Pressure*: 16.0 psi +or- 2.0 psi (110 kPa +or- 14 kPa) @ 2300
T444E/175 HP @ 2300 RPM [49 States 1995 Model Year is EFRC 2111, California 2112]
EFRC 2111, & 2112(California)
A/R Ratio: 1.0
A/R Ratio: 1.0
T444E/190 HP @ 2300 RPM [49 States 1995 Model Year is EFRC 2121, California 2122]
EFRC 2121, & 2122(California)
A/R Ratio: 1.0
A/R Ratio: 1.0
T444E/210 HP @ 2400 RPM [49 States 1995 Model Year is EFRC 2231, California 2232]
Model: T444E/A210F(49 States)/ T444E/A210C(California)
EFRC 2231, & 2232(California)
A/R Ratio: 1.0
A/R Ratio: 1.0
Intake Manifold Pressure*: 17.0 psi +or- 2.0 psi (117 kPa +or- 14 kPa) @ 2400
Smoke Level Max* - Bosch Number: 1.3 @ 2400 RPM / 1.3 @ 1500 RPM
T444E/210 HP @ 2300 RPM [49 States 1995 1/2 Model Year is EFRC 2141, California 2142]
EFRC 2141, & 2142(California)
Injector Part Number: OEM: 1822890C1
Turbocharger Part Number (With Wastegate): 1823560C91
A/R Ratio: 1.11
Intake Manifold Pressure*: 17.0 psi +or- 2.0 psi (117 kPa +or- 14 kPa) @ 2300
8.0 psi +or- 2.0 psi ( 55 kPa +or- 14 kPa) @ 1500
T444E/230 HP @ 2300 RPM [49 States 1995 1/2 Model Year is EFRC 2151, California 2152]
Model: T444E/A230F(49 States)/ T444E/A230C(California)
EFRC 2151, & 2152(California)
A/R Ratio: 1.11
11.0 psi +or- 2.0 psi ( 76 kPa +or- 14 kPa) @ 1500
A/R Ratio: .84
A/R Ratio: .84
A/R Ratio: .84
A/R Ratio: .84
A/R Ratio: .84
A/R Ratio: .84
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.0
A/R Ratio: 1.11
A/R Ratio: 1.11
