cadillackid
I took my radiator completely out... , I wouldnt "poke at it".. but a power washer thats not turned up so high as to bend the fins but high enough to push things out is good... but that only cleans the outdoor fins.. I had my radiator steamed so the inside was free of corrosion and build up..
as for the dash switch, correct +12 to the A/C terminal. the idea is that on A/C vehicles you want your fan on anytime the compressor runs.. with a school bus, the A/C condensers are separate so you can use that input on the controller for a manual switch..
I just got that new version of PAC to put on mine so I can change the fan temp with bluetooth.... the old version was a PITA to set up.. havent installed mine yet.. im still on the 2750 without BT.. that controller needs mounted in the cab, dont mount it under the hood or outside.. you can put it under the dash or inside your switch panel area without harm..
I wired my clutch to the fan Low terminal and programmed only for low (single "speed") since its a clutch and not a dual relay electric fan..
