I have a 95 International 4700 flatbed with a T444E, today loaded I was running along at 55. Started loosing power and slowly dropped to 45 MPH on flat ground with my foot on the floor. Shifted down, and started picking up speed and then it ran fine the rest of the 5 miles home. I had this problem about a year ago and pulled the fuel pressure regulator apart and cleaned it, and blew air back to the fuel tank in both the supply and return lines. It has ran fine since then until today. I did that again as well as cleaning the rock screen on the fuel bowl. Checked fuel pressure at idle I have 50 psi, Wide Open in Neutral it drops to 35-40 then picks up to about 52 then bounces around between 40-50. Pump getting weak? Thanks
