gs1949
I spent much of the 70s in the Yukon. Perhaps global warming has made a difference, but in those days there were 4 to 6 weeks every winter when the daily high never got up to -40 F. As far as lows go, there was a time every winter when the low temp was somewhere between -60 F and -70 F for up to a week or two at a time. And there was one time it went down to -73 F.
Obviously these temps are rough on vehicles. Especially without electricity like I was. I started my old Ford pickup by warming it up with a Coleman naptha gas powered camp stove, upon which I placed an oil can with both the top and bottom cut out to better direct the heat where I wanted it. And, yes, I managed to start that old 223 that time it went down to -73. But I always had 2 fully charged batteries kept warm in the cabin. That time it got so cold I was on the second battery when that old 6 banger finally started. After that I had to sit there for quite sometime, holding the clutch in until the oil in the transmission warmed up enough that it turned back into a liquid. If I had released the clutch before the oil in the trans liquified, the clutch would have burnt up in a few seconds
Back in those days I only ever drove a diesel vehicle when I was working, and I usually only worked in the summer, but I don't know how you'll get a diesel started in extreme cold without plugging it in. Very carefully would be my suggestion.
Fortunately, it's much easier to keep a person warm. Sleddgracer's advice above is quite good, as far as he takes it, but he does not explicitly state what I consider to be the most important principle for dressing for cold weather, which is that multiple layers of thin clothing will keep you much warmer than 1 or 2 thick layers. And with thinner layers it's easier to adjust for differing levels of exertion.
Good luck, I think you may need a bit to pull this off. But I do think you can do it with planning and preparation.
