Sleddgracer
a 'small roof rack' or 'small roof top carrier' might be less intimidating wording for an insurer
When I finally get to that point, my design is a bolt-together, too, instead of a single, welded piece.
Future disassembly if needed, sure, but also to accommodate both my primitive welding skills, and to be able to construct & install, single-handedly!![]()
I have plans, at the moment just running around in my head, of a roof rack hydraulically controlled, or starter motor powered, like some of the old pickup mounted snow plows, that will lower to the ground, where it will stand almost vertical so dog sleds and straw bales etc can be secured, then lifted to the roof with the touch of a button, lever, or remote control, where it will sit flat on the roof - it can then be locked in place while the operator is still standing on the ground - even when I was younger and much fitter than I am now, I always hated climbing onto the top of the truck to secure the load after a weekend of racing in sub zero temperatures - cold, tired, and hungry, fingers and limbs stiff and aching from the cold and effort expended - not having to climb on top of the bus which is even higher than any dog boxes will be the height of luxury for me - lol
How about something on tracks-like a garage door opener? Mounting points allow you to secure the items, and then they slide up. You can always double secure them with simple ratchet straps or something.
Just a thought.
might work - haven't quite got the picture of that in mind - my idea might put you in mind of a convertible top opening up, only no folding allowed - lol
Imagine a garage door-panels and track etc. Only instead of it being mounted to the ceiling of a garage, it's affixed to the roof and side of the bus.
Each panel has tie downs for whatever you're carrying: kayak...
So, to unload, you press the switch, the panels slide down the track with the thing attached, and easy off. Then when its time to pack up, its the reverse. And while the panel is at reach, you also ratchet strap whatever the item is.
Another idea is to do a roof raise-even one for the back third or so, and build the carrying compartment underneath that. So basically the sled etc. is under you. **** of a lot easier to load/unload.
- I've also considered removing the roof over the dog area, ( the dog boxes are already water tight ), and then just pile the sleds on top of the dog boxes like is commonly done on trucks and trailers
That's probably the best idea: sort of like a huge pickup truck with a giant double cab.
Say it ain't so!the only problem I see with that, as practical as it is for my use, is it would likely drastically reduce resale value when that time came
What? You're planning on quitting the race circuit?!Say it ain't so!
I'm 80 years old - I won't have a choice about quitting pretty soon - lol![]()
OK, maybe that is not a particularly good argument!I'm 80 years old - I won't have a choice about quitting pretty soon - lol![]()
Another sled dogger might want it, especially if you've done all of the hard conversion work for them!
If you're truly concerned about resale, don't get a bus. They're constant money pits even after a full on conversion is completed on one in just maintenance costs, annual registration, safety inspections, insurance, etc...
