o1marc
It makes a big difference adding rigid or spray foam insulation compared to the measly batt insulation that's in there.
I'll likely go with the rigid then, unless there's a DIY spray foam.
If it's fiberglass batting, respiratory control is an absolute!
A dust mask is marginal, at best. While uncomfortable; a half-face, negative pressure, cartridge respirator is the safest, most reliable way to go.
Unless you want cancer. Then cheap out with the paper dust mask...
Kinda like me overindulging in a single-malt Scotch; it's safe, if left undisturbed.
Those tiny glass fibers get inhaled, lodge in the alveolae, and all **** cuts loose.
20 or 40 years down the line.
You can sometimes find Tyvek suits, even with the hoodie, for that much or less at HD or Lowes, same day.Yeah screw that!
I'm getting one of those painter's suits: $8.00 on Amazon, and using my respirator!
Thank you for the warning!
iDe nada, amigo!
I've earned my keep as a Health & Safety Weenie on numerous sites, so I take that sh1t seriously!You can sometimes find Tyvek suits, even with the hoodie, for that much or less at HD or Lowes, same day.
Some times...
