Going to attach the steel plate to the floor over the old entrance, so I can later install a passenger seat.
I cut out the steps, but left the metal that made up the "walls" or sides of the steps. Then I framed around that, at floor level, with 1/8x2x2 angle steel.
To cover the opening I am using a plate of 1/8" steel that is 48x48".
I will drill through the plate, angle, and body, and secure with grade 5 bolts.
To fill the approximate 1/2" gap between the steel and the bus floor (cause by the way the angle sits framing the old steps, I will use 1/2" plywood. I will then drill through the plate/plywood/floor, and fasten with more grade five bolts along the perimeter.
QUESTION: Would it be good to use the non-removable 3M marine adhesive between the plate and angle-to seal it-or should I use butyl tape instead?
Maybe it's a stupid question, but just checking in case someone has done this before.
Seems to me the butyl would allow for removal, but why would I remove the floor? I think maybe the marine stuff will add to the structural integrity, while sealing the gap well, without worrying about the butyl eventually dry rotting etc.
