Ok, here's an exterior shot of what it looked like when I picked it up (except the generator cover's hinge is broke, but the cover is shown in the pic):
First thing we did was paint it white. Used three cans of rustoleum automobile primer and just over two gallons of Rustoleum white (didn't paint the roof yet). No pics yet, sorry. I did get some pics when we went to look at it though, so here we go.
Here's the driver's area:
Here's the breakers for the 12volt and the household current. The one for the AC also has some diagnostics, a running counter for the generator hours, and main breakers for the generator and shore power (and it's made so both can't be on at the same time):
This is just behind the passenger seat, the box with wires hanging out is the front A/C thermostat (which just seems loose, A/C works great) and the top box thing is for the heart system. It'll show me the battery voltage, I can turn the inverter on and off, and probably a dozen other things which I haven't figured out (there is a manual though):
Here's the inverter, just under the table in the pic above. Looks beefy, but I wish it was a tad bit beefier. It can run the lights and fridge no problem, but the front A/C is a bit much for it (it'll run for a couple minutes then trip the built-in breaker). The A/C does draw a lot of power though, the battery voltage will drop from about 12.5volts to 11.3volts in the blink of an eye, then hover there until the breaker trips.
Here's a view from the front of the bus looking back:
Here's a view from the back looking forward:
Here's the front door (there's a rear one too which most likely won't be used):
Battery compartment:
Built-in Martin generator (4-cylinder, runs off diesel tank, and provides around 62amps I think):
Bus cost $3,830. I haven't figured the paint cost though, but it'll end up being a couple hundred dollars I'm sure (once you figure in the extra diesel to drive it to the in-laws since they had a paint gun). I've also bought a used Washer/dryer combo (all-in-one, not a stacker) for $250, and an 18cubic foot fridge with ice maker for $330 ($300 plus tax at Sears outlet center).
The front door which will be used most often is bent a little at the bottom (more like warped, whole thing seems off). Since we won't be using the rear door, I'll just swap doors then screw the bottom of the bad door into the side, making it seat good. Then caulk all around it for good measure. It also has a door in the middle for a wheelchair lift. The lift will be coming out, but not until I'm done moving in and out the heavy stuff (loading a fridge is soooo easy with this thing).
The plumbing will most likely end up on the passenger side, since all I have to do is move the generator exhaust pipe a little bit and I'll have lots of room to put the tanks (quick question, if the box is right next to the main exhaust pipe and the tanks are put in that box area, is that too close heat-wise?). The toilet and sink will most likely go right where the middle door is, so that could be an emergency exit (I'll caulk around it, but keep it where you could bust out). Shower or bath will be just behind that in a separate room (basically open the door and you're in the shower). In front of the bathroom will be the kitchen sink, then you have the front door, and just past that is a hump where the generator sits below. I plan on moving the table over 4 inches, giving me enough room to put the washer between it and the rails for the doorway.
The layout for the other side depends on how I decide to do the walls. This thing apparently was built from the start to be a bookmobile. Every 3 1/2 feet or so, there's a metal strip that I think is part of the frame. Between these metal strips are the paneling you can see, with some insulation attached. The paneling isn't screwed into the side anywhere. What they did is cut a groove into the sides of the bookshelves you see, and that goes into the metal strip (like tongue and groove). You then put a screw in the side of the bookshelf next to the wall and it goes through the metal strip. Took me a while to figure out how to remove it, even a sledgehammer wouldn't take it out. Figured out I had to remove each of the tiny screws (they came right out so I thought they were there for no reason), pull the board out, tip it over, then get it out. Anyways...the most efficient use of space dictated that the walls end up in the middle of many of these bookshelves. The walls would be much sturdier though if they were built right where the metal strips were. Just get some 1x2s or 2x4s, cut a groove, screw it in, and it ain't going anywhere! I'll lose about 20 inches of space though, since the rear bedroom would have to be extended in this case. It'll make the kitchen area much more cramped, but may still be doable.
Wheel wells aren't that big inside. On the driver's side they'll end up being where the bunk beds go (regardless of where the wall ends up), and on the other side it'll be where the shower/tub needs to be. We'll just have to end up stepping up into the shower, but we'll still have standing room.
Washer takes 220, but I do have a heater up front that's wired for 220. Will probably take it out, if not I'll at least tap into the wiring and run it to the other side. May test and see if the washer part will work on just 110, if so then I know it'll work fine even if we're somewhere that only has 110 service, and we'll either hang dry or run the generator for the dryer cycle. If not, then we'll run the generator for the whole wash/dry cycle I suppose.
That's it for now, I'll try to update later with more pics.
