Crazy
- Joined
- Feb 23, 2007
- Posts
- 4,236
So happy your making progress.
...and the journey bogs down. The bus is having a hard time pulling the Ex and I am still in Texas where it is relatively flat.
New to the bus world...but I just bought a '91 GMC 4 window short bus with the 350/400 trans. Going to do a camper for me and the wife....I'm familiar with one ton SBC trucks and I what they can do, and I had hoped I could use this bus as a camper, but still pull a U-Haul type trailer with a an old '55 chevy or ford behind it. I thought it would do it, but after reading your post, I'm confused. Why wouldn't your bus pull your load? And will my bus pull my load???? Thanks, Joe.
Like I said, I've had and used a lot of different SBC ton trucks and have done a lot of work with them. Just took it for granted that this '91 bus would act the same as my chevy trucks. I've been using my 2012 Dodge 3500 cummins to pull my old cars with, just thought it would be more fun using an old bus from time to time.... Guess I'll have to wait and hook up a trailer to is to see what it will do...Joe.
Let's go through this. Your Dodge has a lockup converter. My bus does not. Your old cars weigh 3-4000 pounds. My Excursion weighs at least 9000 without all the extra crap I took and my trailer weighs at least 2500 pounds. The GVW of the bus is 23,000 and weighs 16,100 pounds. So I am weighing in at over 27,000 pounds with the Ex on the trailer behind the bus. I could have just pressed on and ignored the temp gauge and dealt with whatever happened in the middle of nowhere. I cross over 7,000 feet at least twice on the way home. My decision was based on caution and nothing else. My bus probably never had more than a couple thousand pounds of students in it. It is in excellent condition, so why ruin it. Every time I hit a small hill, the temp would climb from 180* to over 210*, then the fan clutch would kick on and the temp went down. All this while on the flats of Texas.
I don't know if you are aware of the wonderful split radiator that International uses but I feel it is inadequate for heavy duty use. When I change the trans and radiator to a larger one, I should be able to tow a house without problems.
