RamRod4
I've got a question tangentially related, if anyone's got an answer.
We need to fabricate roof rack mounts that will support two lengths of superstrut or square steel tubing, each length running fore-to-aft, which will be positioned directly above the two internal roof 'ribs' that also run fore-to-aft (if this doesn't make sense, I can supply pics or clarify). If the roof was flat, I'd imagine these mounts to be like an upside-down letter 'T'. But since the roof is not flat, I need to account for the curvature of the roof, and angle the vertical portion of the 'T' so the superstrut / tubing presents a flat surface upon which to mount stuff.
How would y'all suggest I measure that angle? For what it's worth, I'll probably hand this off to an experienced welder.
If I were fabricating it for myself I would build the first T bracket in place and then make the others to match the first one.
1. Level the bus left to right
2. Make flat plate for bottom of T
3. Screw down plate to roof
4. Make upright portion of T
5. Hold the upright plumb with a small level or digital angle indicator (I have a small magnetic digital angle finder from Lowe's that works well)
6. Tack upright to bottom plate while holding it plumb
7. Remove bracket as one piece and then measure the angle and re-create the same part x number of times.
Hope that makes sense.
