Window (and other) deletes, part 2
Well, so much for hoping to have this complete by end of this week lol...I'm maybe halfway there, not quite, but hoping it goes faster now that I've done a few and figured some things out.
I also got distracted with hatch deletes and 8-way deletes (thus the "other" above).
We had a few rainy/humid days, so priming was out of the question since I'm effectively doing it outside, and my foot/ankle was getting worse so I knew I needed to take a break from ladders and constantly running up and down the bus steps. So I just worked on a few loose ends.
First loose end...cut away some of the upper support where the shower skylight goes to maximize headroom:
I tell you what, I'm loving these metal nibblers more and more...I try to use them instead of the angle grinder to minimize dust and noise, and man they're honestly faster, and leaves a much cleaner cut. Like using a jigsaw, you gotta get creative cutting out notches like this though.
There's still plenty of meat there for structural support (most of the load bearing is in the curved part and the bottom lip, as those can't buckle as easily).
Just now as I'm looking at it, I feel like I might want to take a round file to the corners to ensure it can't stress crack...probably not needed, but should do it to be safe.
I also decided to start removing some of the reflective stickers...mostly because there's some reflective strips on the window borders that I want to remove before installing the window deletes, as it'll be harder to remove afterwards.
So I started with a tip I read somewhere else (not sure if here, or r/skoolies) to use a torch and heat until it starts to bubble, then scrape off. I sat down and worked on the large lower "School bus" lettering and reflective backer...
It went horribly. There was basically not enough temperature difference between the sticker bubbling and the paint bubbling...so I ended up ruining a fair bit of paint before giving up and trying something different. It also looked like the metal underneath was some sort of galvanization, but smoother than normal galvanized. I did some research and it turns out it's galvannealed. It's more paintable than normal galvanized, however it's still not great for paint adhesion...that might explain why my original bus paint isn't too determined to stay on.
I had a glass scraper (the kind with razor blades) to remove the emergency lettering from the glass, and figured I'd try it next on the body stickers...and oh my god that was a game changer. It was so easy, and did very minimal (if any) damage to the paint.
Bottom left: glass scraper. Bottom right: torch and metal scraper
Just a little sample of how satisfying it was...
Then I decided to fully install the 2 deletes which I had already primed with self-etching primer rattle cans. Thanks to
@nikitis to spark some ideas how to make it easier to hold the panel in place...this technique worked out pretty well
I threw one of the old windows in mainly to fill the hole rather than putting the plastic back up, but also to see how it "felt"...and figure out if I still want to use the old windows (with new frames of course)
It helped me to realize that I want to try to reduce the massive "forehead" on the window frame by moving the glass up when I make new frames, so when looking from inside the top of the window is above eye level.
I used my clamps to squeeze down the butyl tape between the screws so the panel lay as flat as possible against the original bus body...later this gap will get a small bead of sealant to act as a first defense, with the butyl tape as a backup.
The next "little" task I thought I'd knock out quickly was to remove the 8-ways and trace them to make the deletes for them, since they're not simple circles as on other buses.
Also I knew I needed to fully remove them and not just paint over them because the front ones were cracked and leaky
I started with a rear one because it was easier to access from the inside, and first tried to cut away the sealant inside...but still not enough room to get a blade all the way around it.
To get an understanding of how these are installed (the bulb type, not the new LED ones which are easy to replace), the housing is installed from the outside, then sealant is applied on the inside to "sandwich" it around the metal body panel. So this is why I was trying to cut around the sealant on the inside...but that wasn't happening on the sides and bottom edges as the framing is in the way.
So then I was trying to cut and pry around the edge from the outside, but the body panel is recessed where the lights go, so it wasn't possible to get a blade around it either.
So I had the bright idea to buy some windshield cut-out wire and use that. It arrived 2 days later and I gave it a try from the outside...it quickly cut through the sealant, but was really struggling to cut through the plastic. I couldn't use it from inside-to-outside as intended because the housing reflector part was in the way...so I eventually gave up on that and decided they're coming out no matter what, so I grabbed the hammer...
It was not brittle at all...it took the hardest whacks I could dish out and it was barely breaking, not enough to help remove it. I tried to hammer the lens itself and it was indestructible, at least without a bigger hammer.
So then I took my multi tool and started cutting out the lens, now I just needed to figure out how it was constructed, and cutting away the lens might help me to use the cut-out wire the proper way.
The wire still wasn't cooperating, but a piece of the bezel finally broke off and I could finally understand the construction, and how to remove it.
So I took my multi tool and cut about 5/8" in from the outside of the bezel, all the way around, this allowed me to fully remove the bezel, and essentially the outside layer of the "sandwich"
Then a strong push from the outside, and pull from the inside, I was able to break past the remaining sealant and free the housing.
After a bit of scraping with the knife to remove the sealant (and some paint), finally have a big hole!
The next one I was able to remove the entire bezel intact, to use to trace the patch panel
The fronts where much easier to remove, because the bottom edge wasn't a sandwich, and being so dry rotted they just busted out with little effort
After cleaning up most of the sealant...
Note that the fronts are a different size/shape than the rears. After tracing and cutting the panels for them...
...I only had the roof hatch deletes left, and that'd be all the metal patch panels ready to prime and install. I figured I'd want to paint them all at once (boy was that funny to think I could do them all at once) so I moved on to the roof next.
The roof hatches were finally something easily removable! They were only held in by the trim ring which I had already removed, and some butyl tape. No screws, rivets, or adhesive
While up there I determined that I'd definitely need to reseal the lap joints and coat the roof with an elastomeric coating, but that's for later. I cut 26" x 26" panels and predrilled holes to screw them down at 8" spacing, and they'll also be installed with butyl tape and edge sealant.
Side note: I'm removing both original hatches because I want to maximize solar panels, so I don't yet know where I will have room to put vents. I am putting skylights in, both are right next to each other (hallway and shower) to minimize solar panel layout disruption. The bathroom is getting a 6" dome fan that'll fit under the solar panels, and the forward area and garage area will get vent fans once I figure out how much room I have left for them so I can choose the largest that will fit (I love the maxxfan deluxe)
With all the panels ready to clean and prime...I decided to convert the bus into a spray booth to spray as many panels at once using an airless sprayer a friend is letting me use.
I set up plastic, sealed around all the sides, a box fan blowing into the space with a filter, and another filter at the top for exhaust where the forward roof hatch was
So I now had a fully filtered cross-flow ventilated paint booth...fancy!
Sadly it could only fit about 1/3 of the deletes down the middle (so I could spray both sides)...but in the end it worked out much nicer than painting outside.
Now for the paint/primer. I went into this knowing basically nothing about paint, other than compatibility is important. So I started doing research to figure out what primer would be "direct to metal", tough, and compatible with whatever paint I might want to use on the bus when the time comes to paint it.
I finally decided on tractor paint, a tough oil based enamel, mostly because it's cheap, tough, and it's literally what Thomas uses at the factory it seems.
So I picked up a gallon of rustoleum grey tractor primer from tractor supply...got the first set of panels cleaned and wet sanded (simple green with scotchbrite pad and hose off worked so much better, thanks for that tip!) and hung them up to paint and wiped them down with mineral spirits.
I unboxed the airless sprayer, started reading the manual, found out quickly that oil-based paints are ok as long as they're only "combustible", but not "flammable". Let me check that primer I just bought....fkkkk it's flammable.
I know enough about pumping liquids from a prior job to know that high pressure pumping and spraying of a flammable liquid is a very bad idea unless EVERYTHING is grounded and all devices are intrinsically safe. Not only is the high pressure pump possibly able to cause it to self-combust, but when spraying a material static charge tends to build up as well.
It was already getting dark, the metal bare and eager to rust, so I went to lowes and bought 6 rattle cans of cheap automotive primer at $6.90 a can (bulk savings, yay...)
I picked up a "comfort grip" for rattle cans as well.
In the end, having a nice controlled environment to spray in, and the comfort grip, I hated rattle cans slightly less, and the panels turned out "certified good enough"
Coverage is a little more than 1 "window" per can, spraying the full panel on the outside, and the edges that will be hidden on the inside (leaving the inside center portion bare metal as the spray foam will coat that).
Anyway, that's it for this week... I'm going to stop trying to predict what I'll have accomplished by end of next week as it's bound to cause delays just by saying it lol.
