carleeno
Build update: odds and ends before SPF
After finishing the furring strips, I went along them with my 4' straight edge and checked for straightness...I found that I had to add some spacer blocks on the 3/8" ply strips in between each hat channel to space them properly from the window deletes, and also had to add spacers on the hat channels themselves where the strips had butt joints to keep the screws from sucking them in at an angle since the hat channel isn't square:
There are a few places where it's bowing inwards towards the living area that I need to fix (probably flip the boards) before spray foam, because once that stuff sets there's no fixing it later.
Got the other roof hatch delete installed (I want to wash the roof before cutting holes for the new skylights)...
...and found a creative way to strap the ladder to the bus:
Finished the front light deletes:
Then decided to scrape off the rest of the school bus decals since I'm going to hopefully start driving it a bit soon now that there's no more plastic covering large holes (to the scale, mechanic, etc)
I'll go back with a rubber eraser wheel later to take off the residue...but I'll let it simmer a while in the open air and hope that it dries out a bit.
I happened to have my old driver seat sitting by the side of the bus...so I scraped this one off in comfort
I figured I'd better finish cutting any holes in the walls/roof before SPF, so went ahead and installed the water fill dish. This is one of the few "actual" RV parts I'm going to use, I'm fully expecting it to break in a few years and at that point I'll make a better one myself. This one at least has a check valve built-in for the city connection, which I'll probably never use.
I love it when dimensions happen to work out perfectly, the split-tank design I'm using means the fittings for the fresh water tank will be directly below the sink, so the fill dish, water pump, and accumulator will all be under the kitchen sink and directly above the fittings for the tank...minimizing hose length.
If I'd used long custom tanks then the fittings would have been about 4' away, under the closet (not where I'd want a bunch of plumbing)
I used some dynaflex ultra to put a bead around each of the 8-way light deletes and along the top of the windshield (removing a valley where water would sit)...I didn't get any pics of it as I was precariously standing on the hood, but it's not that pretty, I'm probably going to have to do some cutting/sanding before painting to get it smooth and flat. I tried filleting it with a tool (and my finger) when it was still wet, but it was skinning over within 30 seconds so it was making a mess with the skin. I guess it's because the metal was warm from the sun, and it was also quite windy and dry.
Today I decided to go ahead and install the diesel heater so I have some heat while working in the bus...but also to help pre-heat the shell of the bus before spray foam in case it's too cold out.
I bought a "turrent mount" that keeps the exhaust heat away from the wood and insulation of the subfloor, but this meant drilling a 5" hole...definitely the biggest hole saw I've ever owned.
My timestamps show well over 30 minutes between those pics...it took a lot of patience (and a tight grip) to cut that out. Finding just the right angle that prevented it from chattering or biting felt like a fine art.
Once installed, it looks like the normal mounting plate from above:
But you can see the benefit of it from below:
I did have to modify it to add the hole and slot for the fuel pump wire, and had to put it at an angle to avoid the weld
Everything fitted up before installing to the floor
I removed the fuel level sender to drill it away from the tank, ensuring I don't get shavings inside, and to get the nut onto the back side of the pickup tube fitting...
The fuel pump is mounted under the floor halfway between the tank and heater (as close to the tank as I could get it, more or less above the rear diff)
After mounting it someone commented that they should be at an angle to keep the outlet higher than the inlet...whoops I'll have to move mine...I'm guessing it traps an air bubble inside and might score the pump over time from lack of lube on the top side.
After quite a lot of priming (I used up all of 15' of fuel line thanks to a long run and gratuitous service loops) I finally had heat!
I really need to clean the roof and get the skylights and vent holes cut...but man I'm not looking forward to that...however I've just about run out of reasons to procrastinate so hopefully I don't report back next week with a broken neck from falling off of a soapy bus roof :wink1:
