enigmamdw
Okay, story time….
Spent the last two days probing and switching, crawling and cussing.
Two days ago I was headed to a Harvest host before heading south when my bus just died. Loss of power(electrical) when the bus stopped moving my dash was off.
Now when you turn the key, nothing happens. No dash, clicks, PCB indicator lights don’t illuminate, nada.
It seems to be isolated to the ignition/run/start loop.
Lights, signals work, good 12v power is getting to all the PCB/fuse/relay blocks. If I jump (fused) power directly to the ignition. It turns on/starts etc…however, my ecm is not getting good power ( likely I’m back feeding the ecm through the ignition circuit). My first thought was faulty/failed ignition switch. But it works and it’s not getting batt power.
For those familiar with HDX RE busses. There is a rear fuse/relay bus called the VEC which I confirmed is being fed good 12v power but probing any and all fuses and sockets in the unit show less than half a volt. The ignition wiring runs from this block through a switch block that it’s mounted to and I can firm that those switches work.
Why is the VEC important? Because the ignition loop goes through it. I was lucky enough to get the ign blueprints from Thomas for a previous problem. I can provide it if it helps someone smarter than me provide some solutions.
Random side note: Inexplicably the ign relay on my cabin PCB(#4) had a lose cap. I bumped it and when I did it closed the circuit and the dash comes on and the bus does it’s system checks. It doesn’t start that way but, yeah, that’s a thing.
Has anyone has the rear VEC fail and if so what were the symptoms? Additionally has anyone replaced the VEC? (Mine is bussman ser# 31174-0 )
Has anyone had a similar symptom and found a fix?
I’m stuck surfing local Walmarts in northern Utah till I can sus this out. Any help would be appreciated. Thanks in advance.
Any questions or tests you can think of, I’m all ears. Electrical diagnostics is quickly becoming my newest ‘skill’ to the detriment of my sanity.
I usually run to ‘Just Answer’ to ping my diagnostics off industry professionals but I’m not getting any responses right now, and this is now kinda problem.
