nikitis
So I searched the forums but didn't find any knowledge of the rear emergency door handle removal process.
I need to remove mine to slide it out and reorient it so the inside handle swings down but I cannot figure out the proper way to disassemble it.
I see a pin like structure in the outside handle under it that is very thin and hollow. With no flat head, Alan shaped, or Phillips or star pattern to turn it to unscrew it out. I figure it's a pin but the metal is sooo thin if I put a hammer to it it will destroy it for sure.
I. The top side it looks more hardy but there is also no shape to the hole. Is this supposed to be an Alan wrench hole that maybe the previous installer stripped completely?
Do I have to unscrew it? Or is this something I just pick a side with a pick and hammer it out?
I'd like to know an answer before potentially ruining it.
Underside:
Top side:
Underside:
Top side:
