Nbigger
I have a 2007 Thomas flat front, front engine. I am stripping it and fixing rust and I have a question on the rail that runs at the bottom below the panels and it meets the floor. Is this a structural rail it’s welded to the side ribs. I noticed some light when I look into the cavity now that the insulation is removed and I want to caulk the seams that are open. I have a few windows that leak and I will probably pull and reseal the ones that I keep. Any ideas or tips would be great not sure if I can cut that rail seal and then weld or make a patch panel to screw over it when I’m done.
Thanks, Nick
Thanks, Nick
