Chad1865
Does anyone have tips for removing the old subfloor out from under the factory AC and heater coolant lines?
I want to keep the AC and the heater but also replace the old plywood in these areas. Unfortunately, their coolant lines seem to be fed through holes drilled in the plywood. It doesn't look like I can simply pull out the plywood without damaging the lines.
I don't have much mechanical experience, so unclipping the lines to remove the plywood feels beyond me.
Here is a picture of the housing on the AC lines and plywood around them. Similar setup on the opposite side of the back door for the heater.
