Those use a ton of water in flushing. Dont recommend a house toilet unless your bus is never going to move and has full hookups.I'm interested in this topic as well. I'm not quite to that point but I also plan to have a water flushing toilet. I plan to just buy a regular toilet from homedepot and add rubber seams and lid locks to tighten the seals, and modifying the vent tube so the upper tank can depressurize during a flush but not spill over After that it can work. Your you can always shut off the water too and do a flush to empty it before traveling. but you'll waste 2-3 gallons of water when you do that.
You probably already know this, for an RV toilet to function correctly it must be directly over the Black Tank, as a result when we were designing the interior layout of the Bus, We located where the Black tank would be and then where the Toilet would go.
As weird as it sounds we designed the interior of the Bus around the toilet.
Peter
I won't be using it that much to be a problem honestly so it would be fine for me. If I did ever live in it full time, I may look into the macerated one turf mentioned as My toilet certainly won't be directly over my tank.Those use a ton of water in flushing. Dont recommend a house toilet unless your bus is never going to move and has full hookups.
Nikitis - are you always solo? Others may have different needs and levels of comfort using the great outdoors. In the rain. At night at 3AM. Kids.I won't be using it that much to be a problem honestly so it would be fine for me. If I did ever live in it full time, I may look into the macerated one turf mentioned as My toilet certainly won't be directly over my tank.
Oh sorry, I may have misread that comment, or you edited it. Either way, I'm the sole man in the family. I have a wife and 2 girls. The two girls don't know what a composting toilet is and would prefer a flushing toilet as that's all they know. The wife probably doesn't care which we use. She'd rather a flushing though if it's feasible. I'm more the one against composting and would rather a flushing toilet.By solo,I believe he was asking if you will be camping alone or if the family will be with you….
A wise planner knows that **** happens..We also used the Dometic 320, having had a much smaller plastic toilet in our Class C the larger elongated Porcelain bowl of the 320 was much better, and the wife had insisted on Porcelain.
We have been very happy with our choice, easy to clean and it has a lip around the inside edge that keeps any liquid in the bowl while driving.
Peter
