milkmania
Ok, I KNOW why the transmission has to be disengaged while towing a 2x4 with all wheels down... Transmission Internals are moving, but fluid is not pumping throughout.
So, your choices are to either disconnect the driveshaft, or use a tow dolly with rear wheels on dolly.
But, if I'm moving under 30-40 miles...
What is wrong with towing with a tow bar all 4 wheels on ground, steering wheel tied off with ratchet strap to seat base, and the engine running on the towed vehicle and in neutral. Torque converter is pumping fluid while engine/crankshaft is running. Sure, it's using fuel... But it'll be less than driving 2 vehicles to get the second vehicle moved!
Being alone, it sure would help! Instead of bothering a friend or family to take you back to second vehicle.
2005 2x4 automatic 5.3 liter suburban is towed vehicle.
Researched that Remco has a driveline disconnect for 2x4's, but haven't looked long enough to shop for best price.
Then there's added price of tow bar & install.
First 2x4 I've had in 25 years... It's nice and paid off, so I don't want to change primary vehicle sales.
