Abbott-SKO
- Joined
- Aug 13, 2007
- Posts
- 758
I am looking around for a small 4x4 pickup to tow with all four wheels on the ground. My budget for this has me in the 1990-2000 range. I would prefer an automatic transmission but I don't want to spend the extra $$$ on a drive shaft disconnect. So far the only automatic transmission small truck I have found that is rated towed "as is" is the Mazda 2001-2004 B series 4x4 truck.
A larger selection of 4x4 trucks towed "as is" from the factory can be found with a manual transmission and I may have to go this route but I would prefer an automatic.
Some full size trucks can be towed 4 down "as is" because of the neutral lockout available but I already own two full size trucks and don't really want a third one as a toad vehicle, although the Toyota T 100 is tempting as it weighs less then some small trucks but is only tow able without expensive drive train modifications as a stick shift. I may end up having to go with another full size truck if I stay with my preference of an automatic transmission.
What experience do some folks have towing a small 4x4 truck 4 wheels on the ground?
