bansil
lets not get to generic sounding with 5spds
example: you can not tow an isuzu amigo,trooper,pup etc with the MUA5 4 down or rear wheels down, w/o disconnecting the rear drive shaft
this is due to a roller bearing on the transmission output into the t-case upon which the "main gear" spins (lay means terms and easiest explanation)
you will kill bearing, which will lock up and vehicle will think it's between low/hi range...not pretty with wheels locked up and smoke, easy fix :wink"
for folks with extra parts (2 different teeth counts and no vin differences)
ooopss long tangent with way too much TMI
back to regular programming and I need to check beef jerky :wink:
