The problem with electronic is that it cuts off access to the average Joe.
They may even understand electrical engineering, but be cut off access to it by encryption.
We should have the right to repair anything and if requested it should be given to us and not held down. I understand they want to make money by taking away your right to repair on your own, but that's not the correct or proper way of doing business. People will still come to the dealership and they will still get business simply because many people don't have the time or desire to do it themselves, but if you do desire to do it yourself you should have full access to the designs and encryption keys to access it and make modifications yourself. You can lose warranty by doing so, that's fair for a business to impose because your modification may go out of spec and break something and we can't expect the dealerships to fix stuff we broke for free under warranty. I'm fine with them imposing detections of modifications to protect warranties for dealerships, but I should still have the right to choose to make those modifications, void my warranty, and not be locked out of my own vehicle I purchased should I so choose.
Sure Mechanical stuff is simpler to fix sometimes, electrical is harder for many but it's just a matter of taking time to learn how it works for an individual and dealers know this which is why they started underhandedly locking things up with encryption so that only they can repair it. That is Morally WRONG!
yeah the encryption and dealer-only stuff is getting out of hand... John deere lost in court over it yet nothing else has been done.. I need to read more zbout how these other manufacturers can continue down the line of dealer-only service after that ruling...
its understandable that a manufacturer could require you to purchase specialized scan tools and software.. and even receive training on it, however people like allison have just made it flat out impossible..
I think most sawe my posts about the plight of trying to get onboarded with the tools i need to build, program, and tune allison transmissions.. and its a dead-end.. if you dont work for a dealer who sponsors you.... (sponsor meaning you have to be an active employee with active access under their allison computer logins).. then you 100% cant get there...
some companies you can simply sign up to be a dealer on paper then just never push the product.. (im a dealer for fujitsu and mitsubishi HVAC equipment) but I never sell it... however I get access to all of the tech related tools and parts so i can diagnose / repair / program the systems)...
from what I understand with international is anyone thus far can still get the proper tools to diagnose / repair even the newest stuff as a non-dealer.. obviously the tools arent free but they still have a pathway for someone to do it..
freightliner appears not to... new holland appears not to.. I dont know about others like cummins or detroit...
the thing with mechanical-only is that engines havent changed a whole lot over the years in their general design.. crank,cam,pistons, rods, cylinders.. whats changed s the electronics...
if you had a garage full of tools to rebuild one mecahnical engine, many of those same tools work to rebuild a different mechanical engine, if we took mechnical diesel injection pumps, Bosch made the majority.. and used pretty much the same idea for all of them.. if you could rebuild one you could rebuuld them all..
once we go to electronic engines we got all kinds of different stuff.. HEUI and CAPS and VP44 and PIezo injectors, common rail style.. and.. every manufacturer had their own softwsre and their own scan tools to work on them...
if i look back on the early 1980's.. dad's international scout diesel had a smaller version of a Bosch A pump, a family friend with a VW diesel had a 4 cylinder version of the same pump, my peugeot diesel i acquired later (1980 model) had the same umpo as the VW rabbit.. I earned to servicde and adjust and work on those pumps.. I bought a 1990 school bus with a DT360.. and guess what its the SAME PUMP overall.. different plungers, different capacities.. with a turbo you have an aneroid, but the first time my bus lost its fuel prime I knew exactly what to do having never seen it.. because the primer was darn near the same as the scout id driven decades earlier..
look at gas cars... before electronics you had spark plugs, wires, a carb, and a dizzy.. the same timing light you used to adjust the timing on your ford worked on a friend;s chevy and mom's plymouth...
sure you had carter and rochester and holley carbs but they all acted the same.. you did the same thing.. adjusted their choke and adjusted the idle mictures and jetted for your engine... they looked different and had a few different adjustments but the skills to do one meant you could pretty much do them all..
not so nowadays... not even close...
