trailer body transplant
bdavis441
Apr 3, 2005
274
Okay, here's a crazy idea. I live in central Indiana, northern IN is the RV/trailer capital of the world. There are THOUSANDS of travel trailers being shipped south by FEMA for temporary housing. I see them on the interstate every day! These are 34 ft. (I think). bare bones exterior, no awnings, looks like a white box. They must be fully equipped if they are being used for housing. Eventually, these things will saturate the market and should be cheap. What if....... you took one of these and put it on a bus chassis, integrating it into the cab portion of the original body. Just a thought.
One thing to keep in mind is frame strength.
Somewhere i read about a bus body that was removed from the chassis. The bus frame was too noodly to drive and kept bending in the middle. Apparently the frame gets a good deal of strength from the bus body.
This problem could be overcome however....
I would like to get more info on that noodly thing I was planning on cutting
off the entire back bus part and building my own RV on top, I have seen many cab and chassis HD trucks and long WB one ton trucks and the
frame was pretty strong and didnt flex much, I am glad you mention this
before I start cutting I will take another closer look at my frame I didnt study it but it looked pretty beefed up.
The house trailers he is talking about is probably 2x2 fur stapled together with aluminum skin inside and out I dont think they were made for 50k miles of bouncing down the hwy.
Do you know if that was a conventional bus or a flat nose? As far as I know conventional skoolies are a bus body stuck on a truck chassis. A lot of people make car haulers out of skoolies and cut most of the body off except for a drivers area. I could understand something like a forward control bus having a less robust frame though.
I thought of this idea when my grandma was selling her 35' camper trailer earlier this year. Travel trailers have frames dont they? couldnt you basically just weld the trailer frame on top fo the bus frame? I'm sure theres a million details as well but the basic idea of putting a camper trailer on a bus seems simple enough. It seems that someone out there must have done this before.
After studying up on building and designing a trailer….I can say Lapeers right about how the combination of the frame and body portion gives any rig a lot of its strength.
Before I started stockpiling steel to build a trailer, I went to the dump here to check out an old 30 foot trailer frame that someone told me could be picked up cheap….
It’s amazing how flimsy those things are .
All you had to do was give the frame a good push at either end to make the whole thing wooble and bend.
It’s not that it was made poorly, it just was designed with the idea that…..
When you bolt the body to the trailer frame that’s when the whole thing tightens up.
School Buses are no different.
Even though a School Bus is a hell of a lot more strong then some cheesy trailer , you’d still run into some pretty serious frame flex if you took off the body.
Not saying you cant overcome those issues…just that a person would need to make sure whatever they attached to the frame had the right stuff to handle that flex and calm it down a bit.
This is just my opinion Brad …. If you do go the route of attaching a trailer body to your buses frame, I don’t think welding it to the frame is the way to go.
I’d just bolt it down to the frame. That way the frame could still flex a bit….and you’d get a nice strong combination. If you did weld the trailer to your bus , I imagine it wouldn’t take very long for it to start falling apart because it would be too stiff.
So I’d seriously think about just bolting it down…plus it also would be a lot easier to take the trailer body off and put another one on if you needed to.
This is a cool discussion. I’ve got a dog in this hunt too.
I can’t do it as quickly as I want to because of my job and the lousy weather here….but even so I have been Hacking off parts of Latcho Droms body.
We need to shorten her up to tow a trailer with. So, I’m getting rid of the approx. 2/3 of the body.
I’ll leave the front on and build a small ‘cabin’ on what’s left .
What I’m going for is something like this pic ….but a lot prettier.
http://www.mobilehomestead.com/latcho2/ ... uuler1.jpg
Michael & Millie, Sitka , Alaska
I like the idea of transplanting a trailer body onto a bus frame.
What's the worse possible thing that could happen? You could end up with a ruined bus chassis, and possibly a ruined trailer body lol
Seriously though, it would make for an exciting challenge. If it's something you know you want to do, just do it, I think you can work through the problems that might arise.
I had lots of people tell me that you can't put a full size jacizzi in a bus. Look where I am at today...
I don’t see any reason a person couldn’t do this….
But….One detail anyone needs to consider and work out…. is a trailer’s main load-bearing rails (frame) won’t sit on Bus main rails (Ones a single axle the others a dualie )
So you’d have to weld up some form additional framing that would attach to either the bus or the trailer frame to match things up right.
Then , whatever you do needs to raised up high enough to take the wheel wells into account ( a trailers wheel well is not going to match up with a buses )
So you’d have to raise the trailer up high enough to clear your rear dualies.
Or you could leave the front section on you bus…..that’s what I’m doing
http://www.mobilehomestead.com/latcho2/ ... opoff1.JPG
And build a deck on the rear section that would clear the dualies ….and put the trailer on that.
Michael
I prefer to take everything out of the trailer and put it into the bus. You will spend a lot less time reframing windows than you would transplanting on a whole body.
I'm with Steve on this one. Cutting a bus body doesn't look like much fun.
I think that you'd be better off stripping the trailer and installing the stuff on the bus.
Robert
Actually cutting up the body has been kind of fun…it’s a big, noisy and somewhat tedious job, But not that hard. :D
Having the right tools to do the project is pretty important and does save a bunch of time and effort..
I took a good sized portion of our last buses roof off with a cheap $20.00 jigsaw and a hammer and chisel. Now that was a hard job.
My arms vibrated and my jaw hurt for a week afterward from all the saw kickbacks I took in the face……
:oops:
But that’s when I didn’t know about which tools were the right ones to use for the job.
I’m using a Dewalt Sawzall and grinder to take the roof and such off our bus now….and they’re doing a pretty good job of it.
The only thing I’m not happy about is I can’t get up on our roof and cut through it using the sawzall because it covered in ice.
So I’m having to make my roof cuts from the inside….which is no fun.
Cutting through the side walls is pretty easy.
I just measure out what I’m going to cut and drill out holes using my drill w/ a holesaw at each corner.
Cut the bottom section out first so it doesn’t bind up the saw blade. Then use the sawzall to take out the sides and top.
I was tempted to rent one of those big monster elec. or gas operated metal cutting saws to do this …but figured sawzalls , at least for me are scary enough to use …so I stuck with the less scary tool.
I have heard it’s pretty easy to cut big sheets of metal using a circular saw and a metal cutting blade, and might try that for the sections of the bus were going to take to the dump.
Poor Latcho Drom. She looks like she exploded! I bet your neighbors are very confused, Michael. LOL!
Michael is right on about a very important point regarding the load bearing design differences of a trailer and a skoolie. His point is well considered and he has a lot of experience we can benfit from. The whole thing seems to me to sound cooler in the abstract than it will be in reality considering all the engineering concerns. A bus frame and superstructure are not built that way on a designers whim. They are built that way to perform safely under many years of vibration and stresses from many sources including road surface, grades, wind resistance, load shifting, sudden stops, etc. It might end up being the coolest thing in the world but the devil will definitely be in the details.
Good luck, Guys.
