ClintThrust
- Joined
- Feb 5, 2020
- Posts
- 18
My transmission overheats almost immidiately when i start up a hill. on level ground its fine. Ive been told that an incorrect fluid level could cause it to overheat. when i check the dipstick hot its pretty close to the hot indicator, but when i check it cold its waaay over the cold mark.
which mark should i go off? the cold ones a lot easier for me to check because i don’t drive the bus a lot, but im hesitant to take that much fluid out and try to run it (it must be a few quarts at least)
By the way, the performance of the gearbox never changes when its overheating, although i stop it when the temp gets all the way up.
Follow up question, the fan turns on sometimes on hills and cools the transmission down, but rarely. is there any way to trigger the fan clutch manually?
