I have an Allison Md3060 that seems to run cool. Too cool??
My maiden voyage in June 2018 from Ohio-Alaska tranny temp was steady at about 130-140* Fahrenheit. This was running 60+mph ALL day (limited to 5 gears). I saw 180* once In some hard Canadian mountain passes and once running the PTO-driven 25kw generator. Here in Alaska it is driven almost daily April-October and the tranny rarely gets much over 100*. Most trips are less than an hour, but it’s not unusual to drive 60 miles at 65-70 (now that I have 6th gear unlocked
). Ambient temps here are typically 50-70 Fahrenheit in the summer, though 2019 we saw 80-90 (heat wave!
). The truck weighed 19k pounds coming up, and about 23k as currently loaded.
Up to about a year ago I assumed this low temp was normal (and panicked a bit on the 180* occasions). Bit most people have mentioned 180-200* as their “normal”.
Heat kills our trannies, but Any problems associated with cool tranny temps?
Also, It’s time to see if anyone else has a similar experience. If this is unique to me then either my gauges are lying or SOMETHING is funky.
What is your “NORMAL” tranny temp? What are common “WARM” or “HIGH” temps that you see.
If known, please mention your transmission model. Vehicle weight and driving conditions are helpful too.
