Im looking into buying an ex 1995 F700 uhaul so I can use the box and the front hood to update my tailgating bus. It has a rockwell 4.33 rear that I thought would also come in handy.
My current bus goes 60 tops, 11r22.5 tires and Cummins 5.9, AT545. I dont have a tach but can say it is pretty much wound out at that speed. This rear is behind a 429 gasser which I guess doesnt really matter. What do you think my top speed would be? My bus has air brakes and this truck has hydro. Would it be easier to just swap the center or to swap the axle and brakes, hub etc?
I would also like to take the A/C system and install it on the bus. I dont know what will be salvageable. Will have to get a top mount bracket for the compressor and possibly a new compressor or make an adapter if it is not the same. WIth some rigging I think I can make it work.
Last piece is the hood, I have the boxy 1992 hood and would like to update it to the more modern hood from the 1995. It apprears to alsmost be a bolt on swap, am I wrong?
