bikeforthelight
anfarber said:I am curious whether it is possible/safe/advisable to use the alternator on my DT466 to charge a deep cell battery to be used in a battery bank for ac power.
First off, I plan to charge the batteries off the alternator from the engine - one at a time - because there is room for a third in the battery compartment. I understand it is not good to mix types of batteries but the 8Ds for the bus are expensive ($150) so I plan to go with a cheaper option. My first question is an automotive question. Is it safe to use the alternator as a charger?
Second, I am planning on a battery bank with an inverter for the AC power. Using two deep cells to power the AC outlets at a time, one battery on standby, and the fourth in charging. The standby battery will be switched to be charged when the vehicle is shut off - say midday - then restarted for more travel. I am not sure on my power usage for now (1 laptop, 1 computer, various battery chargers for electronics, 3 reading lights, and 1 RV air conditioner unit.) My second question is whether or not two batteries can supply enough power for my needs? I figure the four battery system (charging, standby, and 2 battery bank) will be manageable on a daily routine for charging as well as cycling out at a 50% DOD.
Third, I have a concern that this system may be detrimental to the cranking batteries since the "AC battery" will be drawing a greater charge. I could use some advice on this subject.
Thats a bunch of info man. Here are my thoughts. First off, you are not gonna run any air conditioner off of batteries and an inverter. At least not any longer than a few moments. You are gonna have to have either shore power or a genny to give enough power for you to run your A/C.
I am confused by what you are planning on doing. Are you gonna move batteries under the hood and let the alternator charge them all day? Are you gonna be driving during that time or parked? You could put in a battery isolator and have them all charged at the same time from the alternator. But in all reality your gonna need to have another way to charge the batteries like a converter/charger, solar, or both. An alternator is made to keep batteries topped off, not to do continuous deep charges. If you really want you can add a second alternator and have the line run just to your battery bank, that way you would never have to move batteries. But I wouldnt rely on that unless you are gonna be keeping them charged from shore/genny/solar power in between and the alternator is just to keep them topped off.
If you are gonna have a battery isolator that takes care of any problems you would have with mixing batteries though. And it also fixes any problems you would have with cranking batteries. It keeps your batteries separate. You need to have two different systems. Your battery bank that runs the cabin area needs to be completely separate from your engine cranking batteries. This stuff took me a while to understand too. Here is a copy of my wiring diagram so you can see some of what I am talking about.
