desertfather
I've seen a few threads about rear decks that extend from the bus frame, and I think it's a great idea, especially as I embark on a shortie build. Even a small space outside the rear door when parked would be really useful. I'm curious: is it possible to build a short rear deck using wood bolted to the frame, and not metal?
The orthodox solution here, I know, would be to bolt metal extensions onto the frame and then cover them with wood decking. But let's say you use treated 2x8 wood joists, bolt 5 or 6 feet of the lumber into the big C-channel beams running underneath the bus, and leave 2 feet extending through the bumper at the rear, and lay your decking on top of that. Let's say, too, that you're not going to put anything heavy on the deck while driving. Would it work?
This tells me that it would be fine for a normal, non-moving deck: https://www.decks.com/how-to/43/deck-joist-cantilever-rules-and-limits
But I'm wondering whether the stresses of driving might somehow cause it to break, although I'd think it would take a huge amount of force to snap a 2x8 joist.
What do y'all think? Terrible or possible?
