Bjorkinman
Hey all, I’m about to pull the trigger on the electrical components for my build and trying to decide between a Multiplus 2 24/5000 or a Quattro 24/5000. I already have the wiring installed for two solar arrays totaling 2800 watts, rails mounted etc. plus the 7 panels are in the garage. Q cell 400 watt each.
I need the 5000 VA capacity that the Quattro offers, other wise I would get a Multiplus 3000. I stumbled on the Multiplus 2 24/5000 yesterday that offers the same output capability for about 800$ cheaper than the Quattro. The main difference I see is the Quattro accepts two 120 inputs, say a generator and a shore inlet and the multi 2 only accepts a single input. The “2” in Multiplus refers to its ability to accept 50 amp shore connection enabling a 240 supply via leg 2 to power 240 devices (I don’t have any 240 devices). For cost savings it seems like a better fit to buy the multi 2 and just use the single 30 amp connection and leave the leg 2 output empty and run all loads from the output of leg 1. I will have a Honda 2200 generator on board for backup and 600 amp hours of 24v batteries. The devices I have are: two mini splits front/rear, propane/electric 12gallon water heater( switch to electric when we have extra solar), washer/dryer (propane dryer) air fryer, occasional hair dryer for the wife, espresso machine. We could probably get by with the 3000 but I don’t wanna have to jockey appliances and turn things off to make dinner
Does it sound like the multi 2 5000 would work as I intend it to?
Thanks all.
Thanks all.
