Wagner spray painters and your bus
Billsman
Nov 10, 2007
87
Buffalo, NY
Has anyone considered using a Wagner power painter to shoot their bus? Everything I've been reading says it can be done. I'm thinking of trying it unless I hear back that it wouldn't work. Thoughts? http://www.wagnerspraytech.com/portal/h ... 0,747.html
About HVLP sprayers (High Volume Low Pressure)
Wagner's HVLP (High Volume Low Pressure) sprayers produce professional results with exacting control. Specifically designed to spray light bodied materials, HVLP sprayers use air to control the shape and size of the spray pattern. Whether you are spraying your deck or finishing a table, Wagner has a sprayer to suit you needs.
Level: Consumer / Professional
Project Type: Indoor - Outdoor
Project Size: Small - Medium
Surface Type: indoor furniture
outdoor furniture
lattice
wood fence
metal
stucco
Paint Type: oil-based, stain, varnish, sealer
Technology: HVLP (High volume low pressure) Air Turbine
Paint Supply Capacity: 1 quart - 1.5 quart
Available Accessories: Yes
Most adhesives are alcohol based, try some of that and see if it works. It may take something stronger than isopropal, try some everclear (180 proof). If that doesn't work then try goof off. sportyrick
Cigarette Lighter fluid- naptha? worked really well on the adhesive residue under the vinyl letters that acetone and mineral spirits would not budge.
