I'm about ready to put insulation in the walls. I'm going with 2" polyiso foamboard with an aluminum backer. Questions for those who've done foam board in the walls:
Did you trim down the rub-rail screw tips before putting the foam in, or just press the foam over the screws?
Did you glue the foam to the outside wall? Glue the inside panel to the foam?
Did you fill all the gaps with spray foam from a can? Lots of caulk? Tape the seams?
Did you do anything specific to avoid squeaks while running down the road? Did it work? What would you do differently?
Thanks a million!
Thanks a million!
